The Procedure Dependencies folder displays the installation procedures on which the procedure is depending on for successful execution.
Drag and drop installation procedures from other software packages to add dependencies.
Select one of the following actions:
If you drag and drop onto the Procedure dependencies folder, a context menu appears with the choice:
