Previous Topic: Volume DirectoryNext Topic: Volume Property
Volume File
A file within a directory of a software package volume. The columns contain information about the file, for example, name, size, type, modification date, and attributes.
When you right-click a file, you can choose between the following actions:
Open
Open the file.
Copy
Copy the item to the clipboard.
Scan Viruses
Perform a virus scan for the item.
The action itself is carried out not by Client Automation, but by the virus checking program configured.
It may be the case that the virus scanner is using another name of the software (based on its UUID) than Client Automation.
Note: This feature is available when a CA virus scanner is installed. Otherwise it is grayed out in the dialog.
Delete
Delete the file.
Tip: You can drag and drop directories and files from the Windows Explorer and add them to the volume. You can also use the clipboard.
