Previous Topic: Fetched Item Source FolderNext Topic: Fetched Item Dialog
Fetched Items
The fetched items folder displays the items that have been fetched from the associated area. Apart from the fetched item name column, there are three more columns in the right pane:
Fetched Item
Name of the fetched item
Comment
If one was entered when the fetch item order was created
Received
Date and time when the fetched item was received
Copied
No, if no copy has been made of the fetched item, Yes, if the context menu command Make a Copy has been used to make a copy, in a selected directory, of the fetched files.
