Use the Configuration tab to specify detection module configurations manually or with the help of configuration files.
Note: Do not change any specifications in this tab for the existing modules unless you have specific requirements.
This tab contains the following field:
Displays the configuration file that will be executed together with the module. For user-defined inventory modules (and some asset management modules) you can create a specified configuration file that will be executed together with the module itself.
Note: Most of the predefined asset management inventory modules cannot be configured with this configuration file method. The one exception is the User Account Inventory Module and WBEM Inventory Module can be configured using this configuration field.
