Select the Remote Control, Previous Sessions node to populate the Previous Sessions pane with a list of sessions that were initiated earlier to hosts controlled by the current Remote Control domain manager. You can switch between sessions by selecting one from the Previous Sessions pane. You can view details by double-clicking a particular session to access the Session Information dialog.
This pane contains the following fields:
Displays pane-specific tips for selecting options or entering information.
Displays the time that the remote control session started.
Displays the computer name of the remote control host.
Displays the computer name of the remote control viewer.
Displays the user name or ID of the session's remote user.
Displays the length of the remote control session.
