You can clear the contents of the Recently Recorded Sessions folder at any time.
All the recently recorded sessions are removed from the shortcut list, but the actual recording files are not deleted.
Note: If you want to remove individual sessions, right-click each session that you want to clear and click Remove Shortcut. The session is removed from the shortcut list, but the actual recording file is not deleted.
