You can replay any recorded session.
The session is added to the Active Replays node, and playback starts automatically.
A sub-menu opens, letting you select a replay speed.
The default is Normal Speed.
The recorded session plays back the session (frame by frame) at the speed you selected.
Note: You can change the active replay session speed at any time after the file has been opened, even while the playback is in progress.
