Previous Topic: Remote Control ReplayerNext Topic: Recording Remote Control Sessions
Set Replayer Properties
You can configure how the Replayer operates by setting its properties. Use the Replayer Properties dialog to configure scroll mode operation and set optimization levels for the replayer's Time Elapse slider bar.
  1. Go to the Context menu.
  2. Click the Properties tool bar or right-click the Replayer and select Properties.
    The Replayer properties dialog opens, displaying the following fields:
    Auto-pan Follows Recorded Mouse
    Specifies how the auto pan mode operates. The Auto-pan Follows Recorded Mouse option does not enable or disable the Scroll Mode option for auto pan, but rather changes the way auto pan mode operates.
    Auto-pan contains the following values:
    True
    If you select the Active Replay Scroll Mode, the recorded movements of the host mouse cause the playback window to pan and follow the recorded mouse pointer.
    False
    If you select Active Replay Scroll Mode, the playback window auto pans to follow the local mouse only when you move it over the recording window.
    Note: The local mouse pointer takes priority in dictating the auto pan position.
    Default
    True
    Use Smoothing When Magnifying
    Specifies whether a smoothing filter is used when magnifying a recorded image. You can use the Use Smoothing When Magnifying option with the Active Replay scroll mode, Scale to Fit. If you enable it a smoothing filter is applied to the image when you scale the recording up. The filtering removes the blocky effect of enlarging a recorded image. The filter takes effect only when the replayer is in the Scale to Fit mode and when you magnify the image, so that it fills the replayer window.
    Default: True
    Example: Image Normal Size
    Before Magnification example
    Example: Image Magnified, No Smoothing
    Magnify No Smoothing example
    Example: Image Magnified with Smoothing
    Magnify with Smoothing example
    Use Smoothing When Shrinking
    Specifies whether a smoothing filter is used when shrinking a recording image. You can use the Use Smoothing When Shrinking option with the scroll modes, Scale to Fit and Shrink to Fit. If selected, the rows and columns of pixels that are lost in the scaling process are merged to give a more accurate image when scaling the recording down. This greatly improves the readability of text when scaling the image down. This filter takes effect only when the replayer is in Shrink to Fit or Scale to Fit mode and shrinks the recording, so that it fits in the replayer window.
    Default: True
    Before Shrinking example
    Example: Image Shrunk, No Smoothing
    Shrink No Smooth example
    Example: Image Shrunk with Smoothing
    Shrink with Normal Smoothing example
    Use Alternative Smoothing Method
    Specifies whether the Use Alternative Smoothing Method option is used with the scroll modes, Scale to Fit and Shrink to Fit. This setting changes the filtering method that the Use Smoothing When Shrinking option uses. If True, a bilinear filter is used to provide a smoother scaled image, but the result is fuzzier and it is slower than the default smoothing mode.
    Default: False
    Example: Image Shrunk with Normal Smoothing
    Example: Image Shrunk with Alternative Smoothing
    Shrink Alternative Smooth example
    Optimize Replayer Slider-Bar
    Lets you quickly move to any point or event in a recording by using the Time Elapse slider bar during a replay. Move the slider bar to the right for better performance. The approximate time that is required to jump to any point in the replay is listed below the slider bar.
    Every index file requires approximately 350 KB in disk space, depending on the resolution of the host computer. As the performance increases, more index files are created on the hard disk.
    Note: If set to Less Disk Space, you can use the Time Elapse slider bar to move to any point in the recording. However, this can take long time when jumping to a point near the end of a long recording.
    Note: Index files are created during the first play through of a recording file. Therefore, this setting has no affect on performance when jumping to the end of a long replay immediately after the file has been opened.
  3. Select or clear the required options and click OK.
    Your settings are saved.
