You can view the images captured with a support OS image to decide whether to retain them or delete them.
To view or delete the images captured with a support OS image
The local OS images are listed in the right pane.
The Local OS Image Properties dialog appears.
The page lists all the images captured and the associated model computers for the selected OS image.
Note: Deleting a model computer deletes all the associated images.
The selected image or model computer is deleted from the image store.
