Asset Management › Inventory › Protection › Viewing the Status Information at Various Levels › View the Status Information at System Level
At system level, you can view the overall status of a selected computer, and also the product states of CA Anti-Virus, CA Anti-Spyware, or CA HIPS for that computer. You can find the appropriate status in the Overview area, the Agent Status area, and the Instant Diagnostics tab.
To view information at system level
- Navigate to Domain, Computers and Users, All Computers, Computer.
The Homepage pane appears.
- View the overall protection status for the computer in the Agent Status area.
- View the status information for CA Anti-Virus, CA Anti-Spyware, or CA HIPS in the Overview area. For example, you can display the information for the following fields:
- Anti-Virus Status
Displays Anti-Virus status
- Asp Status
Displays Anti-Spyware status
- HIPS Status
Displays HIPS status
Note: The CA Anti-Virus, CA Anti-Spyware, and CA HIPS status must be made visible manually by using the Add to Overview functionality.
- Click the Instant Diagnostics tab and see the overall status of the protection agent plug-in.
