At the domain level, you can view various types of system status information, such as violated policies, failed jobs, software licenses exceeded, and so on, right out of the box. For example, you may want to view a list of computers with an inactive status for eTrust ITM or CA HIPS agents or resolve any unsealed virtual application packages detected in a scan.
To view information at the domain level
The domain Overview pane appears.
Examples
Select Violated Policies and locate Protection - CA Anti-Spyware - Status Inactive for a list of computers with an inactive status for eTrust ITM. The list is displayed based on the predefined policies.
Select Violated Policies, locate Assets with Unsealed Virtual Application Images, and click the associated link to access the computer with an unsealed software definition. Update and seal the unsealed virtual application image definition accordingly.
Note: You can create custom policies and also configure the policies to be displayed on the Overview pane.
