The protection status provides an overview about the current security status of each single computer. The protection status can be Protected, Not Installed, or Not Protected, and it depends on the combination of the states of each product status (CA Anti-Virus, CA Anti-Spyware, CA HIPS).
The following table lists different protection states:
Int Value |
State |
Description |
3 |
Protected |
At least one protection application (CA Anti-Virus/CA Anti-Spyware/CA HIPS) is installed and all the individual states of the installed products are "Operational." |
0 |
Not Installed |
State of all 3 protection applications (CA Anti-Virus/CA Anti-Spyware/CA HIPS) is "Not Installed" or "Unknown" (no protection data retrieved yet or agent object is preregistered.) |
1 |
Not Protected |
Protection data has been retrieved and at least one of the individual states is different from “Operational” and “Not Installed.” |
Note: Administrators can use these states in queries to quickly find the unprotected systems in their IT environment.
