Previous Topic: ConfirmationNext Topic: Assign OS Image
OS Installation Management Tab
The OS Installation Management tab displays Information about OS Installation Management
Enable this computer for OS Installation Management (checkbox)
If this checkbox is checked, the computer is enabled for OS Installation Management. If not, you can check it, to enable the computer for OS Installation Management.
Note: You may disable the computer from OS Installation Management with "Delete from OS Installation Management".
Name
The name of the computer will be displayed. If not, you have to enter a valid computer name here.
Host Name
The DNS name of the host will be displayed. If not, you have to enter a valid host name here.
MAC Address
The MAC address of the computer will be displayed. If not, you have to enter a valid MAC address here.
OS Image (current)
Displays the name of the OS image currently installed with OS Installation Management.
Boot Server
Click the option "Assigned automatically" (recommended) or select the name of a boot server from the drop-down list.
