The Advanced tab in this dialog lets you specify the inventory node name for the selected checklist and the organization details.
Defines the component name to use in the inventory file produced by the scanner. This value is used as the top-level group name in the inventory file and hence also appears as the inventory component name under the Inventory, SCAP category in the DSM Explorer.
(Optional) Defines the name of the organization that you want the <organization> tag to contain in the XCCDF result file. Specify the organization name and click Add to List.
Note: You can add any number organizations and move them in the order that you want. The values are hierarchical with the highest level appearing first.
