Use the Post-Job tab to specify the actions to be performed after executing the job. This condition is applicable only for jobs.
This tab contains the following fields:
Reboots the windows agent computer after executing the job.
Displays a message before Windows restarts.
Defines the number of seconds the message should be visible. Value 0 gives infinite timeout.
Restarts the agent computer.
Limits: Windows only.
Deletes the job from the database after successful execution.
Note: The job status is also deleted when the agent successfully completes the job.
