A secure configuration file job ensures that the specified configuration file always equals the content (secure file) specified here.
Whenever a computer starts on the network, the configuration file (for example, CONFIG.SYS) on the local agent is compared with the secure file. If there is a difference between the two files, the secure file is copied to the computer and the existing file overwritten.
Specifies the file you want to secure on the agent. Click the Browse button to select the file.
