You can find the jobs that are not linked to the selected asset or group of assets, and then select the appropriate jobs to be linked to the asset.
Note: This feature is not available for some CA component plug-ins and applications.
To link a job to an asset
The Asset Jobs pane appears.
The Select Asset Jobs dialog appears.
Selected jobs are added to the Asset Jobs pane.
Note: To select multiple items all at once, press the Shift key (continuous selection) or Ctrl key (random selection) and click the items.
