Previous Topic: Information about the Computer JobNext Topic: Job Container Context Menu
Computer Job States
Depending on the type of job, whether the target system connects directly to the domain manager or via scalability server and what download method the target system is configured to use, a number of states will be used to visualize the progress of the computer job.
There are three general types of jobs:
Execution Jobs
Execution job is the common name for installation, activation, configuration and un-installation jobs.
For execution jobs the following states are used:
Used for any type of job and indicates that the job is conflicting with another active job e.g. an attempt to run a configuration job is done while the software in question is being uninstalled.
Library Delivery Jobs
For library delivery jobs the following states are used:
Icon indicating software delivery and job execution error SW Already Delivered
Library Removal Jobs
For library removal jobs the following states are used:
Icon indicating software delivery and job execution error SW Removing Error
