Remote Control › Remote Control Viewer › Viewer Pane › Viewer Properties Dialog › Configure File Transfer Options
You can configure the file transfer options. You can select the time of the transfers, filter files by date, enable or disable encryption, enable or disable the ability to overwrite or delete Read Only files, and enable or disable the ability to preserve attributes of transferred files.
- Right-click the Viewer node and select Properties.
- Select the File Transfer tab.
- In the Confirmation of file transfers group box, select one of the confirmation options.
- In the Filter transfers by date group box, select one of the filtering options.
- In the Misc group box, select one or more of the miscellaneous file transfer options.
- Click OK.
Your file transfer configuration options are saved.
