The Application section lets you add the application to be monitored for installation or uninstallation.
Note: The Asset software policy gets triggered only if the software is installed or uninstalled using software jobs and the software has a related software definition in Client Automation.
This section contains the following fields:
Specifies whether the action should be performed when the application is installed or uninstalled.
Tracks the installation or uninstallation of all the applications in the DSM domain.
Tracks only the application selected in the Application drop-down list.
Lists all the applications (software definitions) in the DSM domain. Select the application you want to monitor.
