Asset Management › How to Start the Asset Management Agent › Change the Agent Run Interval after Installation
The asset management agent automatically runs at the scheduled time specified during installation.
To Change the Agent Run Interval after Installation
- Navigate to Control Panel, Configuration, Configuration Policy, Default Computer Policy, DSM, common components, CAF, Scheduler, AM agent scheduled job.
The current scheduling is displayed in the right pane.
- Double-click the value you want to change.
The Setting Properties dialog appears
Note: The Value field in this dialog is enabled only if you unseal the policy.
- Change the value and click OK.
The changes are saved.
More information:
