The Manage Relations dialog lets you manually register and maintain the relations between assets. You can view the name of the related assets, number of times the relationship was registered and the date and time of last login.
When you right-click an asset in the Manage Relations dialog, the following options are available from the context menu:
Clears the relation counter.
Deletes the relation from the Manage Relations dialog and from the Environment section in the Computer Overview portal.
Opens the Add Relations dialog. Because the agent provides relation information, you can add a relationship to an "agentless" asset by selecting this option for example, you can add an external asset.
Sorts the related assets by the number of registrations (relation counter) in the Computer Overview portal. By default, the relations are sorted by the registration date. Select this option to sort the relations by count instead of registration date.
