InstallShield Parameters
Makes InstallShield setup.exe automatically wait for the installation to finish before exiting.
Runs InstallShield Silent to execute a silent setup. A response file is needed.
Specifies an alternate location and name of the response file (.iss) file. A response file is created using the /r parameter.
Specifies an alternate location and name of the log file that is created by InstallShield Silent.
Provides more detailed information when a setup.exe error occurs.
Runs setup.exe as an uninstallation without reading the script.
Causes setup to generate a Management Information Format (.mif) file automatically at the end of setup.
Tells setup to place the indicated serial number in the .mif file that is generated my the /m switch.
Specifies the language in which the setup runs. Here [language ID] is a numeric language ID of the form 0xnnnn or simply nnnn.
The $ sign should only be used in the parameter macros mentioned above. Other parameters should not contain $.
On /fd and $sl\activate - refer to the sd_swdet command.
