Universal/Uniform Naming Convention. A UNC-path describes the location of a volume, directory, or file.
The format for a UNC path is \\server\volume\directory\file and is not case-sensitive. For example:
\\Shared1_svr\Shared1\WGroups\Network\Orders.xls
Note: The UNC method started with the UNIX operating system. UNIX platforms use the forward-slash character as a path separator. Many network services (ex. FTP) have their origins in the UNIX operating system, so they use forward-slashes instead of the backslashes that DOS/Windows uses.
