Previous Topic: Suspend OS InstallationNext Topic: Computer Group OS Installations
Resume OS Installation
To resume a suspended or already installed OS installation, you can:
Activate an OS Installation:
If you edited a suspended OS installation, you have to activate the planned OS installation afterwards.
Renew an OS Installation:
A failed or stopped OS installation can be renewed immediately.
Reinstall an OS Installation:
In case of a crashed system, you can reinstall the current OS installation.
You have to confirm the installation options, before the OS installation proceeds to the activated state.
You can also delete a planned or failed/stopped OS installation.
To resume an OS installation, follow these steps:
  1. Click on the All Computers folder and double-click the computer with the initiated OS installation in the right hand list.
  2. Click on the OS Installation Parameters node beneath the computer.
  3. Depending on the current state you either have to activate a planned, to renew a failed/stopped or to reinstall a current OS installation.
