Previous Topic: TasksNext Topic: Register / Import Software Package
Create Software Packages
To create a software package, to fill it with contents, and to define the installation procedures for the package, follow the steps in the "Create Software Package" tutorial of the DSM Explorer.
Note: When you create software packages, make sure that you assign group rights to the users for all the files and directories involved in the software package creation. For example, use the command "chmod -R +w /opt/CA/Unicenter/DSM/sd/asm/library" or the corresponding command on Windows.
