Coupled to the use of DTS: Either a delivery job to a staging library has been halted, or the delivery 'sub-job', initiated by checking the Store Package in the staging library box when defining an install (or another task type) of job, has been halted.
This state can also occur if you select Halt for a job to a NOS-less agent using DTS.
After selecting Halt, there is a transitory state, Halt in progress, when a job target is transferring from active state to halted state.
