Synchronization jobs are used to synchronize two directories on the agents by specifying the source where the image is located and the target directory that should be synchronized with the image, and then setting up various options.
This folder lists all synchronization jobs defined in this domain.
To create a new synchronization job, click New in the Tasks section to open the New Job Wizard. This wizard guides you through the creation of the new job.
Note: You can drag a job to an asset or group on which you want to execute the job.
