For editing the backed up files, you can either use the default editor or choose a different editor such as, notepad, wordpad, and so on.
To use an editor other than the default DSM editor to edit your files
The defined file collection definitions appear.
The File Collection Properties dialog appears.
The DSM Explorer uses the selected application to edit the selected file.
