Previous Topic: SystemNext Topic: System Devices
Operating System
The Operating System pane displays information about the operating system installed on the computer asset.
Note: The inventory information available in this pane depends on whether asset management is installed.
This pane contains the following columns:
Installation
Displays information about the operating system installation on the computer, such as the build number, service pack, and install date.
Display Settings
Displays the settings given in the windows display properties, such as the screen resolution, and adapter name.
Regional Time Settings
Displays the regional time settings, such as the time format, date format, and country name.
System Updates
Displays the system update information, such as the update number, installation date.
The following columns display the value for each of the preceding attributes:
Attribute
Displays the scanned inventory item such as total memory and speed.
Value
Shows the value of the items.
Previous Value
Shows the last modified value.
Date
Shows the date when the item was last modified.
Note: You can show or hide these columns.
