Previous Topic: Virtual Application PackagesNext Topic: Create a Virtual Application Software Package Update
The Virtual Application Package Registration Wizard lets you create a virtual application package and import it into the Software Package Library.
To create a virtual application software package
  1. Verify that a virtual application image has been created for the application you want to package. The image should be located on or accessible from the same computer where Client Automation is running.
  2. Navigate to the Software Package Library folder in DSM Explorer where you want to create the package.
  3. Right-click the folder and select Import, Virtual Application Package.
    The Virtual Application Package Registration Wizard opens.
  4. Proceed through the Wizard pages selecting the virtual application image.
    The Wizard creates three virtual application packages: Standalone, Streaming, and Staging. The packages are placed under the Software Package Library folder where you launched the Wizard.
