The Filters portlet lets you specify the source and software types of the applications you want to display.
The following groups of filters are available:
Indicates the following source options: CA Provided, Custom Created, and Heuristic.
Indicates the following software type options: Virtual Application Images, Releases, Virtual Releases, Patches, Virtual Patches, and Suites.
Indicates the following options for the installation format, or mode:
Specifies the display of virtual application images, releases, and patches whose source resides on a different remote system, but is made available to users of the current system.
Specifies the display of virtual application images, releases, and patches residing in the file system of the current computer, but not made directly available to the users of the computer, for example, a server used for streaming the application.
Specifies the display of virtual releases and patches whose source resides on the current system and is made available to the users of the computer.
