This command is used to send an order to register a procedure in the library of one or more domain managers. The command is given to the enterprise manager and directed to a domain or a domain group.
The command is valid for enterprise manager only.
It has the following format:
rregproc item=item_name
version=version_name
procedure=procedure_name
{{area=area_name} | {domain=domain_name} | toAllAreas}
[cname=name]
[sendTime="YYYY-MM-DD hh:mm"]
[haltTime="YYYY-MM-DD hh:mm"]
Specifies the name of a Client Automation domainwhere the procedure is to be registered at the specified product.
You can specify this parameter more than once to address a list of Client Automation domains.
This parameter should not be coded with the domain or toAllAreas parameters.
Specifies an optional unique name of a distribution container.
If no cname parameter is given, a name is generated internally and the command line interface returns this identifier.
Specifies the name of a Client Automation domain group where the procedure is to be registered at the specified product.
You can specify this parameter more than once to address a list of Client Automation domain groups.
This parameter should not be coded with the area or toAllAreas parameters.
Specifies the date and time at which a distribution order should be halted. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm".
Specifies the name of the item where the specified procedure will be registered.
Specifies the name of a procedure to be registered.
Specifies the time to send the associated distribution to the addressed domain managers. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm". If the parameter is not coded, the actual date and time is used.
If coded the related distribution will be sent to all Client Automation domains registered at the enterprise manager.
"toAllAreas" should not be coded with the "area" or "domain" parameters.
Specifies the version of the item at which the specified procedures will be registered.
