Use the rdereg command to send an order to deregister (remove) software items from the software library, at one or more domain managers. The order originates from the enterprise manager. The deregistration order is sent from the enterprise manager to the specified Client Automation domains or domain groups.
This command is valid for enterprise managers only.
It has the following format:
rdereg item=item_name
version=version_name
{{area=area_name} | {domain=domain_name} | toAllAreas}
[cname=name]
[sendTime="YYYY-MM-DD hh:mm"]
[haltTime="YYYY-MM-DD hh:mm"]
Specifies the name of a Client Automation domain where the item is to be deregistered.
The item can specified more than once to address a list of Client Automation domains.
The item should not be coded with the parameters domain or toAllAreas.
Specifies the the optional unique name of a job container.
If a job container / distribution with the specified name already exists an error will be reported.
If "cname" is not coded, a generic name is generated.
Specifies the name of a Client Automation domain group where the item is to be deregistered.
The parameter can be specified more than once to address a list of Client Automation domain groups.
The parameter should not be specified with the area or toAllAreas parameters.
Specifies the date and time at which a distribution order should be halted. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm".
Specifies the name of the item to be deregistered or removed from one or more local libraries.
Specifies the time to send the associated distribution to the addressed domain managers. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm". If the parameter is not coded, the actual date and time is used.
If coded the related distribution will be sent to all Client Automation domains registered at the enterprise manager.
Specifies the version of the item to be deregistered or removed.
