Use this command to deregister (remove from the enterprise or domain library) an item procedure associated with a software program. The item procedure cannot be an embedded item procedure when the product is sealed already.
deregproc item=item_name
version=item_version procedure=procedure_name
Specifies the name of the item to which this procedure belongs.
Specifies the version of the item to which this procedure belongs.
Specifies the name of a procedure. It will be deregistered.
