The copyfetched command is valid only when issued from the enterprise manager.
Copyfetched is used to get access to files that have been fetched from the domain manager to the enterprise manager. Such fetched files are stored in a fetch area of the enterprise manager. Before the files can be accessed, they need to be copied to another location on the enterprise manager.
copyfetched area=area_name
item=fetched_item_name path=enterprise_manager_path_name
Specifies the name of a Client Automation domain where the files were fetched.
Specifies the name of the fetched item. This item name was used by the previous Fetch operation that retrieved the item.
Specifies the path to the items to be fetched., where the fetched item is to be placed.
The path is created if it does not already exist.
