The aregsw command lets you:
aregsw reginfo=reginfo
path=sourcepath [basedonitem=baseproduct basedonversion=baseversion]
Specifies the directory on the system where the registration information subdirectory is located
Specifies the directory on the system where an image of the item being registered is located.
Specifies the product name of the original item on which this new item is based.
Specifies the version of the base product.
