This action lists the attributes of a software policy.
The syntax of the action is as follows:
swPolicy action=showAttr
name=software_policy_name
[swpScope={distributed | local}]
Name of the software policy of that the attributes will be listed.
This option determines the type of software policy involved in the action.
If there is a locally created software policy of the required name then this one is taken, if not it is looked for a policy distributed from an enterprise manager. The latter is on domain managers only.
The specified software policy has to be a policy created at the enterprise manager and distributed to the addressed manager.
The specified software policy has to be a locally created policy.
Note: On enterprise manager all software policies have to be of type "local".
The list of attributes has the following format:
Attributes of the Software Policy «software policy name»
Policy type : {distributed|local}
State : {disabled|not evaluated|evaluating|not conformant|conformant}
Comment : «comment on the policy»
Priority : «priority of the template»
Associated group : «group name»
Group type : {global|local}
Last evaluated : «yyyy-mm-dd HH:MM»
Violators : «number of violators»
Linkage : {batch|transaction|
synchronized|no linkage}
Cascade install : {yes|no}
Degree of automation : {conformity check|setup jobs|setup and activate jobs}
Regeneration of jobs : {yes|no}
Dynamic group evaluation : {yes|no}
Activation time : «yyyy-mm-dd HH:MM»
Enterprise time driven : {yes|no}
Evaluation period : «evaluation period»
Evaluation calendar : «calendar name»
Adhoc evaluation : {disabled|on new inventory only|always}
