This action provides information about the specified job assigned to the specified software policy.
The syntax of the action is as follows:
swPolicy action=showAttrItem
name=software_policy_name
[swpScope={distributed | local}]
jobname=job_name
The name of the software policy at which the job to be shown is located.
This option determines the type of software policy involved in the action.
If there is a locally created software policy of the required name then this one is taken, if not it is looked for a policy distributed from an enterprise manager. The latter is on domain managers only.
The specified software policy has to be a policy created at the enterprise manager and distributed to the addressed manager.
The specified software policy has to be a locally created policy.
Note: On enterprise manager all software policies have to be of type local.
Name of the job to be listed.
The information listed is of the following format.
Show Jobs «job name» of Software Policy «software policy name»
Item name : «name of item»
Item version : «version of item»
Procedure name : «procedure name»
Job task : {configure|activate|
install|uninstall}
Position : «position of the job»
Reinstall required : {yes|no}
Preaction : {none|reboot|logoff}
Postaction : {none|reboot|logoff|
rebootAtEnd|logoffAtEnd}
Prompt user : {yes|no}
..Allow cancel : {yes|no}
..Execute jobs if prompt times out : {yes|no}
..Prompt during (days/hours) : d/h
Run offline from server : {yes|no}
Run at shutdown : {yes|no}
Prevent user login : {yes|no}
Job startup : {local|global} time/{exact|at boot}
Delivery calendar : «delivery calendar name»
Ignore job calendars at target : {yes|no}
Resolve query groups : {yes|no}
Stage item : {yes|no}
User parameters : «user parameters»
Job time out (days/hours) : d/h
