Consider to be shown the assigned uninstallation job shown previously. The following command will provide the required information:
cadsmcmd templateGroup action=showAttrItem name=tg swTemplate=tg jobName="prod 1.0/00:unist"
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Show attributes of the assigned job "prod 1.0/00:uninst" ........from the template group "tg" ------------------------------------------------------------------------------- Job name...............................: prod 1.0/00:uninst ..Item name............................: prod ..Item version.........................: 1.0/00 ..Item type............................: SOFTWARE ..Procedure name.......................: uninst ..Delivery calendar....................: ..Timeout <days/hours>.................: 7 / 0 ..Job startup..........................: local time/exact ..Pre action............................: no action ..Post action...........................: no action ..Job operation mask...................: 0 .........................................ignore calendars on target computers ..User parameters......................: ..Prompt timeout <days/hours>..........: 1 / 0 ..Job task.............................: 2 - uninstall SDCMD<A000000>: OK
