This action allows you to list those groups a group is contained in as a subgroup.
servergroup action=listMembership
name=groupname
[groupScope={global | local}]
Specifies the name of the server group for which the membership will be listed.
Specifies the scope of the group specified. The following values are valid for this option:
The group is a global group, created at an enterprise manager. It may be replicated to a domain manager.
Specifies a local group, created at the domain manager the CADSMCMD is connected to.
If "groupScope" is not coded then the CADSMCMD first tries to locate the group as a local group. If this fails then it is tried to locate the group as a global one.
