This action creates a policy.
comconf action=createPolicy
[name=policy_name]
pType=policy_type
[comment=comment]
[{configuration=identifier}]
Specifies the name of the policy to be created.
Specifies the type of the policy to be created.
The following values are valid:
Specifies a policy for computers and computer groups
Specifies a tailored computer settings
Specifies a comment on or description of the policy
Specifies the UUID of a configuration the created policy will be assigned to.
If "configuration" is not coded then the policy is not assigned to any configuration.
This parameter is mandatory for policies of type "IndividualComputers".
In case of success the policy remains unsealed and the action presents the identifier of the created policy object at standard output in the following form:
Identifier:xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
