To create the encrypted passwords for use with "dmsweep deploy" and "dmsweep stage", use the "caf savecreds" command. This command outputs to a file named cafcreds.txt in the DSM bin folder, and from there you can copy-and-paste the information into the dmdeploy target credential file or use on the dmsweep command line.
Example
caf savecreds "dummy" user "administrator" password "secret" host "machine4"
This example results in a cafcreds.txt file containing a line, ‘machine4’ ‘dummy’ ‘ machine4\administrator’ ‘4DDzqKuSJN5Ml6RsEY+o5Q'.
