CADSMCMD Command Line Interface › cadsmcmd Commands › templategroup—Software Template Commands › General Template Group Management › modify—Modify Attributes of a Template Group / Software Template › Example
Example
Suppose a software template named "tg" is defined on a domain manager. This group is considered changed in the following way:
- The linkage convention should be set to batch job processing with rollback and automatically cascade installation resolution.
- The conformance check should result in the jobs to be activated automatically.
- The software template should be evaluated every 12 hours starting on October 1, 2005, at 01:00 am.
- The time specifications are to be interpreted on enterprise manager time base.
The following command modifies the software template as required:
cadsmcmd templateGroup action=modify name=tg transaction rollback cascade "setup&activate_jobs" evaluationstart="2005-10-01 01:00" evaluationperiod=12 GlobalTime
