Assume a software template tgs that is not associated with a query. To determine the targets the user has to add and remove, the target computer manually while the group is unsealed. Suppose the group is sealed and containing a target HHHHH01B that should be removed and a new target named ORIONXH and SPICAYI should be added. After these changes, the group should be sealed again.
First, a list of all targets assigned to the group is provided by the following command:
cadsmcmd templateGroup action=listComp name=tgs
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- List of target computer assigned to template group "tgs" ------------------------------------------------------------------------------- PPAPPGP0C HHHHH01B KKKKK01A WWWWW01B ------------------------------------------------------------------------------- Number of target computer read: 4 SDCMD<A000000>: OK
Now to modify the list of assigned targets the group has to be unsealed.
cadsmcmd templateGroup action=unseal name=tgs
Next, the HHHHH01B will be removed from the list by the following command:
cadsmcmd templateGroup action=removeComp name=tgs computer=HHHHH01B
The next command will add ORIONXH and SPICAYI to the list:
cadsmcmd templateGroup action=addComp name=tgs computer=ORIONXH computer=SPICAYI
The modified list is shown by the following command:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Connecting to manager "<default manager>" as user "<default user>" ...OK. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CONF USD OSIM ------------------------------------------------------------------------------- List of target computer assigned to template group "tgs" ------------------------------------------------------------------------------- PPAPPGP0C KKKKK01A ORIONXH SPICAYI WWWWW01B ------------------------------------------------------------------------------- Number of target computer read: 6 SDCMD<A000000>: OK
At last, the group has to be sealed by the following command:
sdcmd templateGroup action=seal name=tgs
