To see the attributes associated with job "prod 3 1.0:inst" of "myContainer" enter the following command:
cadsmcmd jobContainer action=showAttrJobs name="myContainer" jobName="prod 3 1.0:inst"
The output will be as follows:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Connecting to manager "wwwww01b" as user "<default user>" ...OK. ------------------------------------------------------------------------------- List of attributes of job “prod 3 1.0:inst “ from container "myContainer" ------------------------------------------------------------------------------- Job name...............................: prod 3 1.0:inst Software...............................: prod 3 1.0 Procedure..............................: instCrash Deliver at.............................: 20035-04-12 10:49 Activate at............................: 2005-04-12 10:49 Status message.........................: OK Overall state..........................: ERROR .........................................0 - job targets waiting .........................................0 - job targets active .........................................1 - job targets ok .........................................1 - job targets failed Job task...............................: install Pre action..............................: no action Post action.............................: no action Prompt user............................: Yes Characteristic flags...................: .........................................local time/exact .........................................calendar controlled Delivery calendar......................: User parameters........................: Prompt during..........................: 1 Days, 0 Hours Job timeout............................: 7 Days, 0 Hours sdcmd<A000000>: OK
