This action allows you to add procedures of products to a procedure group.
The item must already be defined in the software library and the procedure must already be defined for the item.
swLibrary action=addProcToPG name=procedure_group_name
procedure=procedure_name item=item_name version=item_version
Specifies the name of the procedure group to which the procedure will be added.
Specifies the name of a procedure which will be added.
Specifies the name of the item from where the procedure is taken.
Specifies the version of the item from where the procedure is taken.
