If you are connected to a domain manager, you can remove a member from a computer group, by deleting the computer or by unlinking it.
compgroup action=remove
name=group_name
{computer=computer_name}
Specifies the name of a computer group from which one or more members are to be removed.
This parameter specifies the name of an SD target computer, user profile, or docking device to be removed from the group.
The parameter can be coded more than once for removing more than one object from the group.
