This action allows you to list all computer groups including query groups and software templates.
compgroup action=list
{filter=filter |filterfile=file_name}
Specifies the expression to confine the amount of information listed
Computer group name |
string |
Group type |
{Group | Query[/Template] group | Template group} |
Scope |
string |
Comment |
string |
Creation date |
Date |
Creation time |
Time |
Change date |
Date |
Change time |
Time |
Query |
string |
query groups only |
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
