The Status/Input Files table contains the following information about the SCAP data stream files that are processed:
Attribute |
Type |
Description |
Name |
string |
Specifies the file name of the input SCAP data stream |
Type |
string |
Specifies if the input file is an XCCDF or OVAL file |
Location |
string |
Specifies the location of the input file |
Timestamp |
string |
Specifies the date and time when the input file was created |
Size |
int64 |
Specifies the size of the input file in bytes |
